LANZ 3850
LANZ 3850
Beitragvon LANZD3016 » 28.02.2018, 22:56
Hello everyone from Spain, I continue with the restoration of my Lanz Iberica 3850, I need help with the handbrake pulley, it has a little slack when the brake shoes tighten the pulley, I think it may be some bearing, my doubt is ... can it be done without separating the engine change?
Thanks and greetings from Spain
LANZD3016
Re: LANZ 3850
Beitragvon engineer » 04.03.2018, 17:32
Hi,
for changing bearings of the 3rd and 4th shaft you don`t have to separate crankcase and transmission.
After removing the rear-weels,mudguards,transmission top-plate and breakdrum the shaft and bearings can be pulled out sideways.
With kind regards
Thomas Roth
Re: LANZ 3850
Beitragvon LANZD3016 » 04.03.2018, 22:28
thanks¡
LANZD3016
Mitglieder in diesem Forum: 0 Mitglieder und 38 Gäste
