Lanz Type H
all the english stuff about Lanz Bulldog tractors
Lanz Type H
Beitragvon spectrom » 12.03.2009, 07:05
I am looking for some information on a Lanz Bulldog Tractor ownmed by a friend in Australia. He has aslked me to help him sell the tractor and I have set up a sales page at
http://www.cooloolabusiness.com/lanz-bu ... ractor.htm
I have a photo of the Serial plate showing it as
Tractor Type: H
Serial Number: 553565
Model (Drahzahl): 1050 (I am assuming Drazahl is Model as I can't read German).
Would anyone be able to suggest where I can find some history for the tractor and what would be the best way to sell it.
Thanks very much
Allan
spectrom
Beitragvon Chicken » 12.03.2009, 11:04
Hi!
This export Model Type H is the german Type D2416 with a 2-stroke full diesel engine. "Drehzahl" means engine RPM. So this tractor has 24 HP at 1050 rpm!
It is probably built 1956 according to your serial.
you can find a datasheet here: http://www.heinrich-lanz.de/downloads/v ... 6_4016.pdf
Here a short translation:
Type: D2416
HP: 24
Bore: 140 mm
Stroke: 170 mm
Displacement: 2616 cm³
rpm idle: 500 rpm
rpm full throttle: 1050 rpm
Injection pressure: 120 bar
Injection angle before top dead centre: 20 - 24 °
Fuel consumtion: 179 grams per HP and hour
Axial clearance of big end bearing: 0.14 - 0.19 mm
Clearance between cylinder head and Piston: 0.78 - 1.5 mm
Battery: 12 V/56 Ah
Gearbox
1. Gear: 2.5 - 3.5 km/h
2. Gear: 3.8 - 5.4 km/h
3. Gear: 5.4 - 7.5 km/h
4. Gear: 6.8 - 9.4 km/h
5. Gear: 10.35 - 14.30 km/h
6. Gear: 14.4 - 19.5 km/h
1. Reverse: 4.85 - 6.7 km/h
2. Reverse: 13.0 - 17.8 km/h
power take-off: 558 rpm
Size:
Length: 2800 mm
Breadth: 1667 mm
Height with roof: 2300 mm
Height without roof: 1890 mm
Ground clearance: 465 mm
Wheelbase: 1770 mm
Turn raduis: 2700 mm
Weight: 1490 kg
Track: 1275 - 1527 mm
Tires Front: 5.5-16 or 4.5-16
Tires Rear: 8-36 or 10-28
Powerlift pressure: 120 bar
Zurück zu Lanz-Bulldog - in English
